Flush or clear the routing tables for administrative and troubleshooting purposes. The clear and flush commands perform the same function; they remove the contents of the table.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Flush IP routing tables by port:
    action flushIp
  3. Flush the MAC address tables by port:
    action flushMacFdb
  4. Flush ARP tables by port:
    action flushArp
  5. Flush all tables with one command:
    action flushAll
  6. Exit to Global Configuration mode:
    exit
  7. Clear a routing table for a port:
    clear ip route gigabitethernet {slot/port[sub-port]}
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 1/1
Switch:1(config-if)#action flushAll
Switch:1(config-if)#exit
Switch:1(config)#clear ip route gigabitethernet 1/1
The following table defines parameters for the clear ip route gigabitethernet command.
Variable
Value
{slot/port[/sub-port]}
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
